My kickstarter has been rattling, and i wanted to know if any of you expierienced the same thing, my friend had a shee and the kicker rattled right off. so it must be a pretty common problem. I just wanted to know a quick way to fix it..
thanks in advance
My friend has a 2001 yamaha balster and his spark plug gives off a weak spark he replaced it twice now. So its not the spark plug? What can it be?
I know that this is the banshee hq, but i just thought someone might have some ideas... thanks
I live at about 950ft above sea level and i ride alot of mountains, so would that mean i should use race gas with 20cc domes, if so would the 21cc domes work fine??
can someone please explain to me how to install the v-force 2 reeds and tell me if you have to re-jet when you install them. And if putting them on and re-jetting isnt all there needs to be done, tell me what else. Thanks
I want to get NOSS heads but i didnt know what kind of work is required to put them on. What exactly do i need to do when i put them on as in the range of work on the motor. Because my situation is im 16 years old and id be pretty much working on it with my clymer manual by myself and i didnt know if it would be too complicated for me. Thanks for the help!
I ride mostly trails, a drag once in a while, and right now i have stock rears but i have a set of trekkers sitting in the garage waiting to be put on.
Reeds, lighten flywheel, advance timing, noss head or mill the stock head. Then if you want to really beat thier asses port it and put on some bigger carbs.
I'm new to the sport so what does a lightened flywheel and advance timing mean?
I recently bought a banshee and it has Toomey T-5's on it. I want to know what else i could put on it to smoke my friends. They all ride yfz450's and 400ex's, so if you have any suggestions, they would be appreciated. thanks.
I was recently running Silkolene's Pro 2 SX oil, and i just bought the comp 2 pre mix from silkolene. on the back of my old oil it said that it was 100% synthetic and the new one says "synthetic ester based 2-stroke engine oil". I was wondering if i need to do anything special because of the change. sorry it might be a dumb question but i very recently just bought my shee and didnt know if it would do anything to my engine because of the change. Thanks for the help
