It would be good to know what your engine mods are so I could figure if it will be even worth your while to run race fuel. Ill look up a compression chart for domes.
Somebody here probably knows right off the top of their head.
I live at about 950ft above sea level and i ride alot of mountains, so would that mean i should use race gas with 20cc domes, if so would the 21cc domes work fine??
401683[/snapback]
Yea you will be fine with premium unleaded with 20cc domes. If you ever ride at lower altitudes just do a 50/50 mix with race gas.
I agree. At 950' and above you should be fine with 20cc domes and premium pump gas. You might list your other mods to be sure that doesn't change the answer.
-David
