stock porting is not going to work well with this setup. and neither are the sst's. i suggest some proper porting and better pipes...otherwise you are basically wasting your money.
To put that kind of money into it and not port it would be a damn shame. You don't need an all out drag port.
Some builders call it an MX port, some call it an aggressive Trail port...and I'm sure there are other names.
Jeff @ FAST racing, Jim @ Passion Racing, Eric Gorr are all a few good engine builders and come highly recommended on this site.
You do need a better breathing pipe.
T5's are more all around.
Shearer, CPIs and Rockets are more geared toward drag, but...they will make more power on top...period.
Don't forget two EASY\Cheap mods, if you haven't had 'em done already.
Timing plate from Ricky Stator AND a lightened flywheel.
Ask who is doing your engine work what pipe they recommend. If you go the porting route, which...you should...I'd ask that builder.
Tell him how you want to and where you ride. Talk to them about what kind of power you want to make, and they can tell you what kind of porting and pipe combos should work best....
with a 4mm crank you are increasing the stroke so you need porting to accomidate the added stroke, that is how you get the most power out of a stroker motor. you would benefit more with an midrange pipe and an mx port.
