im getting a motor built by a shop here in my hometown. the guy is using a 4 mil hotrod crank w/long rods. wiseco pistons, pro design cool head with 19cc domes using stock carbs with k&n clamp ons. my question to you is can i send you just the cylinders and have you do the port work and the bore and hone or would you need the whole motor. im looking for mainly low and midrange power with out completely killing the top. what would the turn around time be? also if you did this port job what pipes would you recommend. thanks.
thinking of getting a tag t2 bar set up ona stock stem. have you guys done this, and how do yall like it. also if any of you guys have pictures of this setup.
motor is in the shop getting a hot rod 4mil, weisco top end, 19cc cool head, stock porting, fmf sst's, stock carbs jetted up with k&n clamp on's at sea level. how much hp do yall think i will get?
as you see in my sig i only have air filter. just wondering how the rocket pipes affect the entire rpm range compared to the stockers. a dyno comparison of rockets vs. stock would be great. i know i would gain on top but how would the mid-range and bottom be affected. thanks.
