fernando427 Posted July 20, 2005 Report Posted July 20, 2005 I installed my plate today but it fit kinda tight so i got crazy with the dremel now it fits kinda loose. I put it at plus 4 im guessin o is stock. i centered it as good as i could and it seems ok. Also the instructions say that i should set the gap for the magnet thing at .010 to .015 but the closest i could get it was ,022 The bike started fine it ran good on the street does any body think ill have problems when i take it to pismo this weekend? Also I have 22ccdomes do i need to run race gas with the timing bumped up now or should i still run pump? Any help is appreciated. Quote
fernando427 Posted July 20, 2005 Author Report Posted July 20, 2005 (edited) oh yeah i forgot I replaced the seal behind my counter sprocket with a new one and while i was there i saw this funky triangular plastic cover, i did a search and i think its a shift drum cover, Is there a seal behind there? also has any one achanged the shifter shaft seal do i need to remove the shaft? Edited July 20, 2005 by fernando427 Quote
reded Posted July 20, 2005 Report Posted July 20, 2005 No need to remove the shift shaft, just pop out the old with a lil screwdriver and push the new in, after applying grease to it. Quote
fixitrod Posted July 20, 2005 Report Posted July 20, 2005 If the plate is tight, running good and not detonating it should be fine. Quote
superchicken Posted July 20, 2005 Report Posted July 20, 2005 oh yeah i forgot I replaced the seal behind my counter sprocket with a new one and while i was there i saw this funky triangular plastic cover, i did a search and i think its a shift drum cover, Is there a seal behind there? also has any one achanged the shifter shaft seal do i need to remove the shaft? 394702[/snapback] from the micro fish that cover is for a gear switch.i guess so you cant start it in gear.maybe its for the newer ones,but mine never had a wire or anything going to it.there is an oring behind it. Quote
wayfst Posted July 20, 2005 Report Posted July 20, 2005 bend the pickup coil bracket down. i had the same trouble with one that i bought. a little bend and now sitting level and at 10 thou. Quote
switchblade Posted July 20, 2005 Report Posted July 20, 2005 The pin in the shift drum cover is for the rz's. They have a nutrel light in the instument cluster. Quote
Jdawg82 Posted July 20, 2005 Report Posted July 20, 2005 Is there a way we can rig up a light for neutral? I have a hard time finding it and I already installed a modified shift star. Usually I have to just slowly let out the clutch and give it some gas to check if it is in neutral. It would be nice to know that it is in neutral via the light. Quote
rzcolobanshee Posted July 20, 2005 Report Posted July 20, 2005 I'm almost positive you can, as long as there is a little screw on the cover and a tab on the shift drum that touches it while in neutral, then hook up any little light with a hot wire going to it and the ground going to that screw on the shift drum cover, then the light is only grounded while in neutral...make sense? Quote
Jdawg82 Posted July 20, 2005 Report Posted July 20, 2005 Makes perfect sense and something probaly can be rigged up for a few dollars and a trip to radio shack for an led. What does a banshee run off 12v or 6v? So the light is going to be negatively trigged when the shift drum comes into contact with the screw on the cover. Quote
rzcolobanshee Posted July 20, 2005 Report Posted July 20, 2005 (edited) 12v I believe led's need some special resistor though, I believe Justintoxicated knows about that shit Edited July 20, 2005 by rzcolobanshee Quote
fernando427 Posted July 21, 2005 Author Report Posted July 21, 2005 Ill try bending the tab for the pickup thanks Quote
Z28ROC Posted July 21, 2005 Report Posted July 21, 2005 You can buy LEDs at Radio Shack with built in resistors. Just check the package, it says it right on the cover. Quote
Jdawg82 Posted July 21, 2005 Report Posted July 21, 2005 Lol yea I work at radioshack I will check tommorrow when I go in. Quote
yfzkid989 Posted July 21, 2005 Report Posted July 21, 2005 fernando i new seggesting a using my dremil was a bad idea lol your finger nail file was doing fine and BTW good news about the ESR exhaust i will tell you when you get home. later, CHRIS Quote
