i have ran it with the box off and it didnt solve anything, besides i couldnt hear shit besides sucking air with that damn lid off, i have great spark and new plugs. The crossover tube is attached.
well the yamaha shop was out of jets at the moment, and they said i deffinetly need to rejet, but they said i could bring my old ones in and they could drill them out to size? sound leget?
DON"T USE DRILLED JETS!!!!!!!!!!
They might not get them exactly the same, and that is bad. Check for an air leak around the carb boots and reed cage. Check your reeds. make sure they are laying FLAT. If not, take the warped one off and flip it over. If you have problems in every throttle position,that would mean not only are the mains off, but so are the rest of the circuts. I would start by looking for an air leak. If you have a buddy with a Banshee that has similar mods, swap his carbs in and see if it runs better. If it does, copy his set-up and fine tune from there. If you are completely confused by the Banshee gnomes, take it to a reputable builder and pay him to get it spot-on.
  • 2 weeks later...
well it wasnt even but 85 degrees tonight, it ran awesome for like 20 mins with the 210's in it and then started its normal back up again, oh and it spit coolant on the ground it idled high when i stopped, so i tapped on the bowls and when i tapped on the bowl on the kick side it idled back down, so i know one of my floats is stickin, but i just got pissed and put it away, im startin to think i better just pull the motor out and buy a gasket set, go through the whole motor, clean the air filter, check for problems and try again? any suggestions all help is welcome, i really dont wanna have to sell it and have to drop some cash in a new 450 :( i love banshees when there not actin up
Did you try to ride it after you rapped on the carb bowl? Maybe you have a float that's sticking closed when it warms up and it's causes that side to run super lean or miss. Have you tried cleaning the carbs? How about checking the float height?
