02bansheerider Posted July 7, 2005 Report Posted July 7, 2005 I just replaced my rear pads and rotor about a week ago. When i took the old pads out, i noticed the inner pad ( pad closer to the axle carrier) still had about 1/2 - 3/4 pad still on it while the outter pad ( closer to the right-rear wheel) was completely down to bare metal. I went ahead and put new pads in and put in a wave type rotor. Its been about a week and the outer pad is almost completely down to metal again while the inner pad still has a good amount left on it. Has anyone had this problem before? Quote
rzcolobanshee Posted July 7, 2005 Report Posted July 7, 2005 Your caliper is fooked, time to get a new one or put on a 250r caliper Quote
rebelbanshee2 Posted July 7, 2005 Report Posted July 7, 2005 caliper is sticking or your rotor is bend Quote
TopGunnYFZ450 Posted July 7, 2005 Report Posted July 7, 2005 More thumb less finger action my friend will fix that right up! Quote
Rare Scottish Tree Badger Posted July 7, 2005 Report Posted July 7, 2005 More thumb less finger action my friend will fix that right up! 389825[/snapback] I don't think he was using his 'finger action' to work the back brakes. Rare. Quote
decon Posted July 7, 2005 Report Posted July 7, 2005 probly a bent rotor if one pad had more material than the other. just change the caliper and rotor all together to be sure. Quote
02bansheerider Posted July 8, 2005 Author Report Posted July 8, 2005 well i put a brand new rotor on with the new pads so i didnt think it would be the rotor. So most likely i need a new caliper? thanks Quote
fast87 Posted July 8, 2005 Report Posted July 8, 2005 58 cents says it is dry of lubrication , remove the caliper bolts and sand them, next coat them in grease(a semi-thick, even layer), then re-install, more than likely you're caliper isn't sliding, so the only pad that is used is the inner..i actually think it's the bolts that mount it to the rear bearing hub that slide..remove it and find the sliding pins, i'm also pretty sure they have rubber boots at each end, shove a little grease in there also(with your finger or grease gun, wipe off the excess) ~Mark~ Quote
FASTOYS Posted July 8, 2005 Report Posted July 8, 2005 58 cents says it is dry of lubrication , remove the caliper bolts and sand them, next coat them in grease(a semi-thick, even layer), then re-install, more than likely you're caliper isn't sliding, so the only pad that is used is the inner..i actually think it's the bolts that mount it to the rear bearing hub that slide..remove it and find the sliding pins, i'm also pretty sure they have rubber boots at each end, shove a little grease in there also(with your finger or grease gun, wipe off the excess) ~Mark~ 389972[/snapback] DING DING DING/WINNER!!! Fast87 is correct ! The sliding pins are frozen and the caliper cant slide so it wears the pads REAL fast on one side!! I use anti-sieze on them after i get em cleaned up! Quote
