Quick question before I put this engine back in the chassis.
What do you guys think the MAX piston to cylinder clearance should be before boring?
Im at .035 now.
Thanks.
I can't answer your question, but it will also depend on what type of pistons you're using.
The Clymer states 0.0024" - 0.0026" for clearance.
My 0.040 Prolites stated "Clear 0.0030".
That seems like a lot of clearance you've got :shrugani: . Measured right or did you mean 0.0035"?
Rare.
my old set of jugs and pro lites had .0040" clearance, that's borderline..my new set is like brand new, but isn't really needed, with the cost of boring then a new top end kit, i woulden't od it, run yours the way they are and i highly doubt you'll crack a skirt, how old is the top end??
~Mark~
200 bucks now (for pistons and bore) while it's still apart or 200 bucks 6 months later and the fun of tearing it apart again as well as possibly sustaining more damage if you do break a piston skirt.
You'd be much better off with a fresh top end...just my .02 :shrugani:
bigboybanshee-where do you get a bore job and pistons for 200 bucks??? it costs me 100 about anywhere for boring, then top end kit(pro-lites) are 150-160...you must be getting a good deal or sumthin..
~Mark~
