fast87 Posted July 5, 2005 Author Report Posted July 5, 2005 well i pull on the lever(on top of the engine case) and it goes till it lines up with the arrow on the case then stops completely, nowhere in that travel does it even start to move the clutch pressure plate.. ~Mark~ Quote
Rare Scottish Tree Badger Posted July 5, 2005 Report Posted July 5, 2005 It's your hand lever/ perch whatever you want to call it. That's what'll pull it further (with the cable attached and adjusted ). You keep saying "pull" which is confusing me . Does the mechanism's pointer sit towards the outside of the casing arrow, or towards the centre of the case when it's just resting? Rare. Quote
fast87 Posted July 5, 2005 Author Report Posted July 5, 2005 it sits towards the outside with no pressure on it, but i figured out my problem, my clutch is much stronger than i expected, and could barely pull it in with 4 springs attached, so all is well in the banshee engine once again , and i have also found a new respect for my clutch cable and lever, that thing really has some weight to pull!! (if you don't believe me reach down there and try to pull in your clutch by the lever on the engine, VERY hard), anyway thanks for all the help, i think i got all i need...except somewhere along the line i seem to have lost my damn stainless bolts that hold on my stator cover ~Mark~ Quote
GYTWYPT Posted July 7, 2005 Report Posted July 7, 2005 it sits towards the outside with no pressure on it, but i figured out my problem, my clutch is much stronger than i expected, and could barely pull it in with 4 springs attached, so all is well in the banshee engine once again , and i have also found a new respect for my clutch cable and lever, that thing really has some weight to pull!! (if you don't believe me reach down there and try to pull in your clutch by the lever on the engine, VERY hard), anyway thanks for all the help, i think i got all i need...except somewhere along the line i seem to have lost my damn stainless bolts that hold on my stator cover ~Mark~ 389059[/snapback] contact Rob at [email protected] and i am sure he will give you a good deal on a set of stainless allens. tell him Joe sent you from HQ. later Quote
