Anyone run them? I have been looking into them trying to find some more info about them as far as setting them up. Thinking about going with some of their 34's.
380080[/snapback]
DUDE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I just got a set of 36's. There so F**KIN SICK!!!!!!!!!!!!!!!!!!!
The only thing i had a problem with was finding some manifolds for less then $200
But they are sooooooooooo easy to set up.
check out packardracing.com, thats where i got mine.
really dude dont even think about any other carbs
There by far the best, others cant even compete
I love our lectrons. We run 34s that came from fast by gast but I would definetely call up Dennis Packard. We run a Packard Lectron on alky on one of our polaris and the carb came spot on. They are super easy to tune, the hardest part is getting the tops off.
i run one on the cr500 banshee. tuning is simple once you understand how to do it. all the adjustment is in the needle and then mine has a powerjet on top for top end. bad thing is they are fuckin expensive...id check PS for someone selling them.
Yeah...but, tell you what...Loco. From what I've read, they aren't as sensitive to temp changes, and...as you can attest, are much easier to tune once dialed in...
Living in MI...you never know. It was 70s here one week, and literally we got 3 to 4 incheds of snow the next. Literally....
It'll be nice to just twist the needle a bit for the ice racing. Also...Loco, from what I've read, a conventional bigger carb will cause you to lose on bottom to gain on top.
The way these Lectrons are designed, you don't loose nearly as much off the bottom and still kill 'em on top...
What do you think?
:cheers:
no they arent. once you get them dialed in theres nothing to it. i havent done anything to mine and there has been a 20 degree temp change since i tuned it. runs as strong as it did the day i tuned it.
What do you think?
:cheers:
380765[/snapback]
i played with the 40mm keihin and the 44 lectron when i was tuning it and the lectron had more power everywhere than the keihin. they are good carbs, just pricey as fuck.
:cheers:
380765[/snapback]
I remember that week..... :shootself:
Ever since my bro put a 44mm Lectron on his yfz I have been sold on them! They are simply the best carb out there imo. But like Loco said, the only downfall is they are spendy as hell!
Well...I just signed the deal on my first house today...(Insert...finally...here)
So...I'll be on a tight budget for a little bit...but, they are definately on my list of stuff to get.
I've heard they're a bit wacky to get used to, but easy as hell to tune and hard to beat on power...sounds like it's all true!!
Yep it's true, there F**KIN SPENDY!!!
Here is my cost tally:
-$605 for 36mm Lectrons (included throttle cable)
-$100 for pro design manifold
-$40 for pro design reed spacers (so i could clear the clutch leankage)
-$10 for fuel lines and filter
-$110 for pod filters- though i got em for $70 from packard (there f**kin huge)
Sorta Spendy :cry:
But like they say, you get what you pay for
Im hopein to get a lot of W's at the face of sand mountain :evil:
Sorta Spendy :cry:
382324[/snapback]
Did you get your bike into Packard yet?
