Banshee0028 Posted June 8, 2005 Report Posted June 8, 2005 (edited) Ok, last time I went riding it was about 20' cooler than it was this time. Now its about 80-90' where I ride at here in FL. Last time out everything was about right on, possibly a bit lean on the main, but ran great!!! Now for the first time, I noticed a pretty good bog\hesitation\ and sputterng a little in the midrange. If I let it get to about 75% or so, it will open up great WOT!!! Off idle is ok, and starts ok. It does take a while to start when cold, but thats been like that for a while, prob due for a rebuild one day. So, I am thinking I need to lean out the needle for the hotter weather, right? I think its at the 4th position from top, 27.5 pilot and a 280 main. I tried to go higher on the main previously and got nothing but boggs and non-starts. It has most bolt ons, vforfce 2's and a mild home-MX porting job. Do I need to go richer instead? Edited June 8, 2005 by Banshee0028 Quote
justinklumb29 Posted June 8, 2005 Report Posted June 8, 2005 I would try to go a little leaner on the main jets. the warmer the air the leaner you have to jet it. Try going down to 270's to see if that helps at all Quote
locogato11283 Posted June 9, 2005 Report Posted June 9, 2005 i would try a 270 and see what happens. what do your plugs look like at 280?? Quote
Banshee0028 Posted June 9, 2005 Author Report Posted June 9, 2005 i would try a 270 and see what happens. what do your plugs look like at 280?? 379583[/snapback] hmmm...weird, thats 3 votes to reduce the mains!! I would think since WOT is fine and only the midrange is bogging, I would need to ruduce the needle position? I have not pulled the plugs since the last ride, but previously they looked right on. I have not done a "true" plug chop recently, but prob need to. I do have a set of 270's here I can put in, but thought the needle would be much easier... If the mains are causing the prob, I can try the 270's this weekend Quote
Big Blue Posted June 9, 2005 Report Posted June 9, 2005 If you lean out the main it will also lean out your needle. Quote
locogato11283 Posted June 9, 2005 Report Posted June 9, 2005 those circuits overlap more than you think... Quote
