ww90stufrey3 Posted May 23, 2005 Report Posted May 23, 2005 I have an '01 Banshee, it has a K&N filter, Prodesign intake, and std Wiseco pistons. I hadn't ridden it for several months and recently gotten it out. It ran fine for several hours, then it started bogging down much like when a plug gets fouled; in fact, the left side exhaust went away. I replaced both plugs and it idled fine, revved fine; however, when I took off, it bogged down really bad. Also, it makes a slight winding noise that I hadn't noticed. I use bel-ray H1R oil, mixed at 40:1. I have a lot of oil in the airbox. I never re-jetted the carbs when I installed the K&N. I still smokes really bad and fouls plugs more often than before the K&N. I run it without the airbox lid. Any suggestions? Do the pipes get clogged? Should I clean them out? How? When I feel the exhaust on the left side, it feels as though there is not compression. You know, it just feels like a continous flow of air rather than the charges of compressed air coming out. Thank you! Quote
wayfst Posted May 24, 2005 Report Posted May 24, 2005 check your reeds on that side (left) and clean the carbs. try that first. Quote
jeepman380 Posted May 24, 2005 Report Posted May 24, 2005 Do you have your e-brake disconnected? Mine did that one time also and that was the problem. Quote
banshdog Posted May 24, 2005 Report Posted May 24, 2005 Do you have the TORS on your bike? Did you check your compression? Clean the carbs. Did you use fresh gas? Quote
banshee76179 Posted May 24, 2005 Report Posted May 24, 2005 Do you have the TORS on your bike? Did you check your compression? 373203[/snapback] Word!!! Quote
switchblade Posted May 24, 2005 Report Posted May 24, 2005 Word!!! 373254[/snapback] You might have bad gas. It is an easy fix just empty the tank and put in new. if that fixes the problem great. Quote
ww90stufrey3 Posted May 25, 2005 Author Report Posted May 25, 2005 You might have bad gas. It is an easy fix just empty the tank and put in new. if that fixes the problem great. 373263[/snapback] It was the gas! I put fresh gas in and it works just fine. I should know from being in medicine that if I hear hooves, look for horses, not zebras! Quote
switchblade Posted May 25, 2005 Report Posted May 25, 2005 It was the gas! I put fresh gas in and it works just fine. I should know from being in medicine that if I hear hooves, look for horses, not zebras! 373551[/snapback] glad I could help Quote
