I have an '01 Banshee, it has a K&N filter, Prodesign intake, and std Wiseco pistons. I hadn't ridden it for several months and recently gotten it out. It ran fine for several hours, then it started bogging down much like when a plug gets fouled; in fact, the left side exhaust went away. I replaced both plugs and it idled fine, revved fine; however, when I took off, it bogged down really bad. Also, it makes a slight winding noise that I hadn't noticed.
I use bel-ray H1R oil, mixed at 40:1. I have a lot of oil in the airbox. I never re-jetted the carbs when I installed the K&N. I still smokes really bad and fouls plugs more often than before the K&N. I run it without the airbox lid. Any suggestions?
Do the pipes get clogged? Should I clean them out? How?
When I feel the exhaust on the left side, it feels as though there is not compression. You know, it just feels like a continous flow of air rather than the charges of compressed air coming out. Thank you!
Do you have the TORS on your bike?
Did you check your compression?
373203[/snapback]
Word!!!
You might have bad gas. It is an easy fix just empty the tank and put in new.  if that fixes the problem great.
373263[/snapback]
It was the gas! I put fresh gas in and it works just fine. I should know from being in medicine that if I hear hooves, look for horses, not zebras!
