ScrewMachine Posted May 23, 2005 Report Posted May 23, 2005 '99 Shee, just bought it about four months ago. Checkin' the tranny oil and it's milky. I'm thinking it's prolly just the impeller seal, but was hoping for some more ideas from the experts here. So whadda tink guys (and gals)?? Anything else it could be? Thanks! Quote
dajogejr Posted May 23, 2005 Report Posted May 23, 2005 I'd check for leakdown, too... Could be impeller, head or base gasket. I know this sounds simple...cause it is. Check ALL of your crankcase/tranny vent hoses. Make sure none are plugged. If they are...the moisture that builds up has no where to go...and there you have it. Milky Way all the way. Quote
rzcolobanshee Posted May 23, 2005 Report Posted May 23, 2005 Could only be the impeller seal or the impeller shaft, unless you been stickin yer dick in da filler hole again Quote
neilgf Posted May 23, 2005 Report Posted May 23, 2005 Could only be the impeller seal or the impeller shaft, unless you been stickin yer dick in da filler hole again 372918[/snapback] Quote
ScrewMachine Posted May 24, 2005 Author Report Posted May 24, 2005 unless you been stickin yer dick in da filler hole again 372918[/snapback] Ya mean I ain't supposed to be doin' that?? But I just can't help myself, the Shee turns me on soooo much! wtf do I do now? Quote
joker149999 Posted May 30, 2005 Report Posted May 30, 2005 i would say it's the lower base gasket leaking but that's just my two cent's Quote
locogato11283 Posted May 30, 2005 Report Posted May 30, 2005 just wonderring but have you noticed that you coolant level has dropped? also is there oil particles in the coolant when you take the radiator cap off? sounds like you def have a bad seal tho. Quote
ScrewMachine Posted May 31, 2005 Author Report Posted May 31, 2005 just wonderring but have you noticed that you coolant level has dropped? also is there oil particles in the coolant when you take the radiator cap off? sounds like you def have a bad seal tho. 375324[/snapback] Yeah, coolant level has dropped some, but no oil in the coolant. Took it apart yesterday... oil was extremely fuct up. Milky (of course) and all kinds of mush laying in the bottom of the tranny case. Was tinkin' it might be clutch fiber, but the discs are in good shape. Impeller has some fairly deep grooves, so I'll be getting a new one of those and a new seal along with a new o-ring for the coolant transfer through the case. Throw her back together and we'll see. Wish me luck. Quote
MILO Posted June 1, 2005 Report Posted June 1, 2005 at least you caught it with only a few grooves in it. mine was completely wasted except for a little bit of plastic left on the shaft. the stock ones suck. it's only a matter of time till they fly apart. pro design makes a nice replacement. more advice, get ready for a clutch rebuild. the antifreeze will eat up the bonding material of the clutch fibers and soon leave you with a slipping or wasted clutch. i checked my oil before going out, and it was fine. a few hours lately it was milky and my clutch was slipping pretty bad... get ready to get your hands dirty and break open the piggy bank Quote
ScrewMachine Posted June 1, 2005 Author Report Posted June 1, 2005 Aw, shit! Replace the clutch, eh? Maybe that's what all that goopy shiat was in the bottom of the case. I don't mind gettin my hands dirty, but breakin the piggy bank? I'm too broke as it is.... I'll break the clutch down and check the fibers. Thanx for the help. Quote
dajogejr Posted June 1, 2005 Report Posted June 1, 2005 Get Jeff's clutch from FAST Racing...it's only a few bucks more than if you were to buy a boxed Barnett or EBC, and worth the money. I have a alumininum impeller I'm putting in mine probably this weekend. If my stock plastic is in good shape, I'll ship it to you no charge, if you pay shipping. Again, this is the stock one, and it's a 96 with very low hours...so, I don't know how she looks. Just trying to save you a buck...but, in the long run, the alumnium is the way to go. Got mine on a trade and a flywheel puller! Quote
ScrewMachine Posted June 2, 2005 Author Report Posted June 2, 2005 Thanks for the offer but I think I'll be getting an aluminum impeller. If I'm puttin' a new clutch in her, I don't wanna risk this happenin' again. DJ Quote
dajogejr Posted June 2, 2005 Report Posted June 2, 2005 Thanks for the offer but I think I'll be getting an aluminum impeller. If I'm puttin' a new clutch in her, I don't wanna risk this happenin' again. DJ 376790[/snapback] Can't say I blame ya....just trying to help a brother out...low cost style! Quote
