Dead Op Posted May 7, 2005 Report Posted May 7, 2005 Ok i was riding tonight, and my friend on his warrior waas about 10 feet ahead, he turnedx o the highway and gunned it i was stuck in trtafiic, when i gotr on they were 700 yards ahead, of course caught right up! Ihad it pinned then slowed down, they caught up and said my exhaust was sparkin , it was! I rode it slow and sparked otu them more int the left, tyhen i shut it off 2 minutes later started it and no sparks were coming out. just to be a help they are fatty pipes with powercore 2's. oter mods boost, and air filter. Quote
superchicken Posted May 7, 2005 Report Posted May 7, 2005 we should have a spell check. do a search theres a post on this from like 2 days ago Quote
JARE77 Posted May 7, 2005 Report Posted May 7, 2005 Probably just burt packing flying out Hopefully! Quote
Bansheeman1121 Posted May 7, 2005 Report Posted May 7, 2005 Ive had sparks come out of my pipes on 2 seprete occasoins, 1 was when i was lean in the winter and my freind was pinned in 6th flyin around in the snow with the tires spinning at 100 mph for about 10 mintutes, sparks came out the pipes and the expansoin chambers turned bright red where the meet the cylinders, started up the next day only for the lower rod bearing to fail and blow my top end-was there a connectoin beetween the 2 ..... No idea, the other say i saw a few sparks and oddly enough it was becuase a bad plug.. Quote
03bluebansh Posted May 7, 2005 Report Posted May 7, 2005 Ive had mine throwing sparks out, i kept riding hard, ive also had it glowing red down through the end of the pipes, i just set there for a bit got back on and rode hard again and it ran just like it always did. Quote
applpro Posted May 9, 2005 Report Posted May 9, 2005 Ok i was riding tonight, and my friend on his warrior waas about 10 feet ahead, he turnedx o the highway and gunned it i was stuck in trtafiic, when i gotr on they were 700 yards ahead, of course caught right up! Ihad it pinned then slowed down, they caught up and said my exhaust was sparkin , it was! I rode it slow and sparked otu them more int the left, tyhen i shut it off 2 minutes later started it and no sparks were coming out. just to be a help they are fatty pipes with powercore 2's. oter mods boost, and air filter. 365852[/snapback] you need to at least pull the plugs to see if it's too lean! look for specks on the plugs (white/grey) . if you see any, it's pieces of your pistons!! Quote
lincster Posted May 9, 2005 Report Posted May 9, 2005 Ive had mine throwing sparks out, i kept riding hard, ive also had it glowing red down through the end of the pipes, i just set there for a bit got back on and rode hard again and it ran just like it always did. 366074[/snapback] Not very smart to keep riding. Bike is lean. As for sparks, I would say you have a lean condition. Better start doing some checking. Quote
ScrewMachine Posted May 9, 2005 Report Posted May 9, 2005 we should have a spell check. 365855[/snapback] word Quote
Dead Op Posted May 11, 2005 Author Report Posted May 11, 2005 did a plug chop a while ago, and did some other tests it running more on the richer side than lean Quote
stclark816 Posted May 11, 2005 Report Posted May 11, 2005 Ive had mine throwing sparks out, i kept riding hard, ive also had it glowing red down through the end of the pipes, i just set there for a bit got back on and rode hard again and it ran just like it always did. 366074[/snapback] Quote
