87banshee_rider Posted April 17, 2005 Report Posted April 17, 2005 i want to get a k and n for my banshee and was wondering if they actually do anything on a stock banshee? i just wanted to know before i spend the money on something that might not even make a difference Quote
2strokesmoke Posted April 17, 2005 Report Posted April 17, 2005 i want to get a k and n for my banshee and was wondering if they actually do anything on a stock banshee? i just wanted to know before i spend the money on something that might not even make a difference 356451[/snapback] yes it will help dont forget to jet mine runs fine with it worth the money Quote
sheeweet Posted April 17, 2005 Report Posted April 17, 2005 It will make a difference but know that you will have to through in some bigger main jets for the carbs and you might as well get an outerwear for the filter and a ProFlow Plate and remove the airlid for better airflow. Then when you have the bucks get some pipes. Quote
bansheecaptain Posted April 17, 2005 Report Posted April 17, 2005 yea you will feel the difference.. dont forget to go up in jetting Quote
05bansh Posted April 19, 2005 Report Posted April 19, 2005 They are well worth it!! Just remember to re jet like everyone else said. Quote
sheefreak Posted April 19, 2005 Report Posted April 19, 2005 Might as well buy the pro-flow kit w/k+n filter. Is 99.99 most places, have seen it for 89.99 though. In Dirt Wheels about 7-8 months back they did a pipe shootout for the yfz450. Before they started, they removed just the lid on airbox and jetted accordingly, then they dyno'd it. W/just the lid removed made 1 horsepower improvement. Not bad for just removing the lid. Quote
richybanshee Posted April 19, 2005 Report Posted April 19, 2005 (edited) K&N will let more air into the engine. Buy the outware also and ditch the airbox lid. Put some screws throught the airbox to hold the airfiletr assembly in place, later on you can get the adapter plate. K&N filter $40 outware $10 280 mains $03 x 2 total $69 If you want to get and adapter plate, get a cheap one, no need to spend a lot in something like that. Alba action has some, probably other people too. The biggest difference in power comes from the pipes so get ones. Edited April 19, 2005 by richybanshee Quote
Ruko Posted April 19, 2005 Report Posted April 19, 2005 Check out NOSS Machine... he sells the whole set up. It's $90.00 on his web page. Quote
njbanshee Posted April 19, 2005 Report Posted April 19, 2005 I would get the prodesign filter over the K&N. Quote
05bansh Posted April 20, 2005 Report Posted April 20, 2005 I say if you dont ever ride in wet condition then ditch your whole airbox and get clamp on k&n's with outerwares Quote
BansheeBob Posted April 30, 2005 Report Posted April 30, 2005 I say if you dont ever ride in wet condition then ditch your whole airbox and get clamp on k&n's with outerwares 357799[/snapback] What size K&N's did you use when you removed the air box? Does somebody sell a pod kit? Quote
23champ Posted May 1, 2005 Report Posted May 1, 2005 What size K&N's did you use when you removed the air box? Does somebody sell a pod kit? 362464[/snapback] ID - 2.25" OD - 3.5" LENGTH - 5" Rocky Mountain ATV: $46 for a pair. + $20 for outerwears Quote
Oilsmoke Posted May 1, 2005 Report Posted May 1, 2005 ID - 2.25" OD - 3.5" LENGTH - 5" Rocky Mountain ATV: $46 for a pair. + $20 for outerwears 362715[/snapback] www.ajusa.com i just bought some from www.ajusa.com cost was 26.08 for model ru-1720. this was 20 degree angle 2.25 inlet with a 3.5 by 6 inch body. precharger was model ru-0520 , cost was 12.11 shipping was free for a total of 76.38 Quote
