How many of you guys had your engine rebuilt? I've had my Banshee since september, and have approximately ridden it 34 times in 6 months. I dont think the previous owner had his rebuilt before I purchased it. Well a few days ago my shee died on me. I was dreading this day since I got it. No compression on one cylinder and a little in the other. I thought maybe water got into the carbs .. but no. The dealership is quoting me $1,200 on a rebuild :cry: I know it sucks .. but I dont have the time, knowledge or patience to fix it myself. I guess it pays to play. I just dont want this to happend anytime soon. So thats why I'm posting this message to get some imput back.
Thanks for reading ...
Holy crap $1200. That's insane.
If it's just that top end you could do it for way way less. It's not very hard. Where are you located, maybe someone can help you out.
347292[/snapback]
Yeah I know its crazy. I'm in Philadelphia. Banshee is already in the shop gettin worked on.
i`m in philly also. next time call me, my name is john. for a piston kit, gaskets and bore,i could have gotten it done at a fraction.215 880 1990.which theivin dealer charged you that?fun center? city yamaha?
347299[/snapback]
Deptford Honda ... right over the W.Witman bridge area in Jersey. I'll keep you number in the files if I have anymore problems.
347301[/snapback]
How much would all that cost for you to do it? boring, jetting ..ect? ... Maybe I'll have them cancel the parts that they ordered and have you do it instead.
347304[/snapback]
You can usually do it yourself for about $200
50-75 to bore the jugs
130-150 piston kit
cancel that shit, and bring it home.... the guys here can walk you through it. after you get the jugs bored out, it will only take a few hours to pull the top end off, replace the parts, and put it back together
dam thats a fu*king ripoff and my first question is why are you take a yamaha banshee to a honda dealership? i wouldent trust it to anyone that works on hondas they might try and make it run slow so they have a chane when racing a honda.
Edited by redcell43
order your pistons from www.rockymontainatv.com i dont think thats spelled right but go here they have alote better deal than that stealership. you might be able to find them cheaper if someone is haveing a sale(look around on the net). i paid 150 for my prolites.
I'd cancel that work order and get someone like NYUK to do it if you absolutely cant do it yourself. Unless you trashed your crank and cylinders beyond repair $1200 is insane. You could probably get someone from here to do it for $500 total, they'd do it better than the stealer, and they'd be happy to make some pocket change.
347415[/snapback]
yeah cancel the job and have someone that "knows what they are doing" do the work. if you do the work yourself for around $1200 you could get a port job, a new crank, a new top end kit(pistons, rings, and gaskets), your head shaved to bump up the compression, and a clymers manual. if you have the time and the place to work on it, and you are willing to put forth the effort along with the clymers manual and all of the helpful experienced people here to help then you would have a good running shee after you are done. like others have said if all you need is a top end kit then you can get your shee running again for a lot less than $1200.
347354[/snapback]
It's a Yamaha/Honda dealership.
347440[/snapback]
I'm gonna find out exactly needs to be done tomorrow on it. Maybe I left a lot out.
