01bansheefox Posted March 29, 2005 Report Posted March 29, 2005 I am trying to remove my stock u-joint from my 97 tahoe 4x4, I cant seem to remove my rear u-joint from my rear drive-line, any tricks? Quote
joshv5.0 Posted March 29, 2005 Report Posted March 29, 2005 I am trying to remove my stock u-joint from my 97 tahoe 4x4, I cant seem to remove my rear u-joint from my rear drive-line, any tricks? 346555[/snapback] take out the holding clip with some needle nose pliers then take a socket and a hammer and beat it out one way then flip it and beat it the other way. and it will have enough play so that you can remove it. or use a press Quote
01bansheefox Posted March 29, 2005 Author Report Posted March 29, 2005 clip? ok then there is my problem lol ive been banging on the things for awhile even heated them up, where is the clip at? I see nothing at all.... some guy at the auto store said its wax? and when i heat them up it just melts there way loose. *shurg* maybe a picture if possible you can find online, any help with be greatful I really need my car tomorrow thanks. Quote
cb67rs1 Posted March 29, 2005 Report Posted March 29, 2005 some do have teflon in the joints that hold them on, you have to melt the teflon out and knock them out, it you have a vise its easy to knock them out, and use a BFH!! Quote
01bansheefox Posted March 29, 2005 Author Report Posted March 29, 2005 Ok these things have looks like a wax pin thing holding them in and whats a BFH? How long does it take to melt them out? I dont know how long this torch will last I bought one of those blue bottles from Home Depot Quote
Tim C Posted March 29, 2005 Report Posted March 29, 2005 If it's the origional U-joint there is an epoxy that has to be headed with a torch to remove it. When it gets hot enough the epoxy will flow out - then beat the joint out but be careful you don't bend the ears on the driveshaft. Quote
01bansheefox Posted March 29, 2005 Author Report Posted March 29, 2005 well its the original u-joint will a little propane torch be hot enough to heat the entire thing? How long should it take? Will it just come out by itself or do i need to heat it up then try to get a little pick and hit it through? Quote
Tim C Posted March 29, 2005 Report Posted March 29, 2005 well its the original u-joint will a little propane torch be hot enough to heat the entire thing? How long should it take? Will it just come out by itself or do i need to heat it up then try to get a little pick and hit it through? 346596[/snapback] I used acetelene torch so propane will definitly take longer but still should get hot enough. The shit will just start squirting out when its hot enough then remove the u-joint the same way any other u-joint. Quote
CowboyBanshee Posted March 30, 2005 Report Posted March 30, 2005 It will look like a snake thingy from the fourth of july, comes out the top of the ear, you better step up and get a good oxy acetylene unit for this job, and your gonna wanna get plenty physical with it while it heated.....this has to be the shittiest design on earth I swear, I hate there damn things. Quote
Guest nightmare Posted March 30, 2005 Report Posted March 30, 2005 I got mine out with a propane torch. There is regular clips holding it in there too. You probabally already knew that, but if not they are on the inside of the ears on the drive shaft. just pop them off with screwdrivers if you don't have snapring pliars. Hope that helps you out. Quote
