There is so little difference between the 2, there is really no sense to insist on a banshee case and most guys will usemost of the RZ tranny because of the better shift forks and gearing ratios.
Holyman is right. I have actually spent quite a bit of money just to get the shift forks and drum out of an RZ. Keep the RZ stuff and sell off the clusters to make some money back. I "think" there really isn't anything different to running RZ cases, Hell you can even add a tach if you wanted.
So are you looking to trade all that for a set of Banshee case? If you are, PM me.
I have an excellent set of RZ cases and RZ tranny. I am wanting a good set of banshee cases to put a spare motor together with.
341456[/snapback]
i have a set of banshee cases, no cracks at all, straight up swap?
341552[/snapback]
yeah i plan on keeping the forks, but you might want to take another look at the RZ top case where the cylinders set down on them.
If you set Banshee cylinders on RZ cases and take a look under the cylinder in the front of the motor you will notice that the rubber water plug that is on the bottom of the banshee cylinder is kinda hanging out there in the middle of nowhere. I just didnt want to get a good 4mm motor together and have that thing blow out. As for a tach you just need some older banshee cases. They still have the holes for the tach. I think they would be before 95.
If you can take a look at that set up and let me know what you think.
Later
Joe
341720[/snapback]
What year is your banshee cases? Are they numbers matching cases?
As far as my end i am talking about very good RZ cases and the RZ tranny gear clusters. No forks or drum.
Let me know
thanks
Joe
