Contact Dan at A&S he was part in designing those cylinder setups. He had a shit load of them when I was at his shop a few weeks ago
335556[/snapback]
Dan may have had some behind the scenes part in the design but there were a few others ;) that had more input than Dan.
holy opened up intakes.....how are those things gonna pull on the low end?
335672[/snapback]
I don't think the port play out on these was ever meant to be a good trail monster. I'm sure anything can be ridden, but I "heard" these things have exhaust timing geared a little more toward top end. Either way they are incredible, Calvin has out done himself again. But, this time for a reasonable amount.
Nate McCoy (more-torque on Ebay) seems like a pretty good and knowledgeable guy. I had some dealings with him.
so is there some other dynos on these besides A&S sheets.
337219[/snapback]
I'm not sure yet. I know Ohton was going to dyno his sets, More Torque will be dynoing his 7mm sometime next week if all goes to plan. Trinity who knows. Trick no idea but they are or will be introuble for listing the cubs for less than 875. Southern style I don't know if they will be dynoing anything close to stock... there are a ton of shops that have these cylinders. I guess I should say this... just because on builder can get 5-10 hp more than another doesn't mean you will be faster than someone else with the same motor from another builder. Being able to put all the power to the ground is what will win the race in most cases. I know... blaa blaa you guys already know this....
