Hey guys, I bought a ricky stator adjustable timing plate but I am having difficulty finding the reference mark on the case? Can you help me out here...pics would be good!!
328663[/snapback]
The mark on the case is the split between the two case halfs.
So you guys are talking about around 2-3 o'clock position, just up from the pick up coil or down from the upper stator attach point...Or is it exactly where the case starts to bend to the right at the 3 o'clock position (ref stator)
Sorry for the stupid questions
Thanks guys...I will look into that tomorrow...any other pointers to give out? I have already installed it once and when I ran the engine the screws backed out of the pick up coil and then it hit the stator and then the bike died...
I had to pick up a ricky stator pick up coil off of ebay and I should be attempting this mod again next week with some modifications to the pick up coil mounting holes...
Thx again :cheers:
