ok, I got my main jet fixed thanks. now when it idle and I give throttle it bog out. when i pull choke it run better but still hard to keep running. does you think me pilot jet is two big o two small?
68mm blaster piston, 4 mill crank, pj34, cpi's, v force, i be at sea level,
My main be 152 and plug be choclate brown. it is very very fast but i had a bad time getting to idle goo. i had 55 pilot then i do 50 pilot it got worse now it have 58 pilot and idles perfect and have throttle response like my dirt bike.
so my pilot was two small
Turn your air screw all the way in. If better you have too small of a pilot jet or your jet is plugged ALso make sure your carbs are in sync.
Chris
Have you tried raising your needles?? Move the clip towards the pointy end. You may also want to try a 60 pilot.
