Leadfoot350 Posted February 3, 2005 Report Posted February 3, 2005 (edited) Is the pro-design ez-drain plate just a plate with with a allen bolt in it? I would like to take my stock plate and do it myself if this is so. Edited February 3, 2005 by Leadfoot350 Quote
MILO Posted February 3, 2005 Report Posted February 3, 2005 Is the pro-design ez-drain plate just a plate with with a allen bolt in it? I would like to take my stock plate and do it myself if this is so. 316734[/snapback] that's the way it looks to me. i guess it's mainly so you don't have to pull the rad hose to drain the system?! it's not worth the $$ as far as i'm concerned, unless your looking to add some looks to your shee. Quote
RNBRAD Posted February 3, 2005 Report Posted February 3, 2005 Is the pro-design ez-drain plate just a plate with with a allen bolt in it? I would like to take my stock plate and do it myself if this is so. 316734[/snapback] That's exactly what it is and I've said before it would be cool to add some fins to it which would help the cooling factor a tad (I think CEJ was looking into this). Of course it's not visible as far as looks go. Quote
kw04 Posted February 3, 2005 Report Posted February 3, 2005 i dont pull the hose to messy just take the cover and the plate off much cleaner that way. Quote
racer Posted February 3, 2005 Report Posted February 3, 2005 That's exactly what it is and I've said before it would be cool to add some fins to it which would help the cooling factor a tad (I think CEJ was looking into this). Of course it's not visible as far as looks go. 316792[/snapback] well that plastic cover goes over it, so clearance would be an issue. but if you machine a new cover, with a portion removed for some big polished cooling fins, thatd be an idea. Quote
brock_fuzzy_69 Posted February 3, 2005 Report Posted February 3, 2005 i am prettys ure that the finned version exists already i think it was in the james lucky catalog or nacs nto sure Quote
Leadfoot350 Posted February 6, 2005 Author Report Posted February 6, 2005 So does anyone have one of these plates? Can I just drill and tap the hole and be done just like the pro-design? Quote
superchicken Posted February 6, 2005 Report Posted February 6, 2005 i did one up last year drilled a small hole about were the pro desein plat has it,welded a 1/4-20 nut on top of the hole and cut a bolt to fit.worked but ended up changing it anyway Quote
