thanks in advance guys
i wanna run aftermarket lights but i want to know how many watts i can run
308201[/snapback]
I would have to look it up, but off the top of my head I think it's something around 35 watts.
Stock stator is rated at 70, so 2 lights at 35 each and you are maxed out. For good lighting, you need to either get a bigger stator, such as the 200 watt available from Rickystator, or some other high wattage aftermarket stator, or go to HID type lights which will give a brighter light off of lower wattages. Some companies recomend that with a stock stator you run one 35 and one 20 watt light.
