so i just got done with rebuild new crank, pistons, had cylinders resleeved from 80 over back down to stock (other mods are in my sig).
when i try to ride it it bogs and i think its due to a way rich condition. my pipes are only reaching temps of around 78 degrees, both cylinders seem to be the same temp. before the rebuild my pipes would be around 250 degrees which is why i think i am way the fuck rich. i would just rejet it but i don't have access to a jet kit right now being it newyears and everything is closed
it has a 370 main jet, which i thought was pretty rich even when i was at 80 over so basiclly i am asking what you guys think. i think my problem is all in the jetting.
also any ideas on what jet i should jump down to? like i said i went from a 66mm piston down to a 64 everything else is the same and i'm at sea level
but i am very happy to hear her run its benn a while
thanks in advance!! :D
Well you can do a few things even during the holiday. First how do the plugs look? If it's running rich you can block off part of the airbox or use a baggy and a rubberband if you've got a clamp on kind of setup. If blocking off the airbox tape or cardboard work well. Just work your way up from a little bit of restriction to more. You don't want to run her lean. Not gonna do you much good anyway except maybe confirm that your rich.
300360[/snapback]
if i pull the choke out it will barely run and the pipes don't get past 80 degrees when its running, so that tells me its defiently rich and i haven't ridden it enough to make the plugs have any type of color change yet.
wouldn't blocking off the air to the carb just make it run richer? if anything i would need to minus the restriction to make it run leaner, i would think. i know i defeintly don't want it running any richer
Haha...wow. Ok I'd really like to say that I was tired or distracted or something. But in reality I just had a total brain fart. Ya blocking off the air would obviously make it richer. Since you already tried the choke trick I guess you're S.O.L. until after the holiday. Unless you wanna drill some holes into your intake :blink:
Since you've rebuilt an entire engine...
I'm sure you've disabled all the TORS crap. I only throw it out there, just in case it was overlooked.
You're probably going to need to go down 8-10 jet sizes. Just do it a little at a time.
BG
Haha Wall, I was like he musta got totally wasted last night. Killed some brain cells in the banshee tuning area of the cerebellum. :jesterlaugh:
I always said I'd rather have a bottle in front of me than a frontal lobatomy. :D
depending on the elevation the main should be around a 310-320.ran a simular set up last year,minus the k&n's and ended up with a 300,at sea level
300555[/snapback]
thanks guys,
it sucks i really wanna ride the damn thing but i gotta get this jetting right first
i really think my problem is all in the jetting, cause the bike sounds fine by that i mean the rotating assembley all seems to be in good order
by the way do you think +4 is to much timing? being that i also have 20cc domes if i'm on 93 octane mixed 32.1? i think i may set the timing back to zero.
thanks guys,
300568[/snapback]
Depending on how aggressive your porting is, you should in the range of 290-330. Keep the timing at +4...make sure you raise the needles. Fmf pipes love richer needles.
300602[/snapback]
thanks for the help you guys :cheers:
and happy new years
and happy new years
300612[/snapback]
well i feel like a feel dipshit
i put the damn pistons in backwards, i gotta switch them around tommorow and see if my woes are gone :shootself:
