bansheewizard Posted December 19, 2004 Report Posted December 19, 2004 my shee seems to get no spark when shes hot , like when i go to ride at a track ill get there shee'll start rite up go out for bout 10 -20 mins shut her off and let it cool off a lil, for bout 10 mins and shee will not start back up so easy take a while and some good hard kicks . any help is appreciated Quote
BlinginBanshee Posted December 19, 2004 Report Posted December 19, 2004 that happened to me when My coil was going bad but it could be a stater also... Quote
kw04 Posted December 19, 2004 Report Posted December 19, 2004 yea it could be the stator heating up then crapping out Quote
itsaripper Posted December 19, 2004 Report Posted December 19, 2004 You have taken the plug out and checked the spark after letting it cool off? From your discription you get it started but that it takes a lot of cranking. My first thought was that the carbs are slobbering over when the motor is hot and not running. That floods the engine. On a nother idea, the coil can short when it gets hot. The coils wires inside get warm and swell up. If there is a bear spot that is rubbed off then it shorts out. Quote
Bansheerider29x Posted December 20, 2004 Report Posted December 20, 2004 i had that problem i found out it was my cdi box that went bad i went through hell to figure it out also i needed a rebuild then so that was another problem for me if u know your pistion and rings are good check your cdi box then the ignition coils then the stators i did mine the other way and i went through hell becuase i did my test wrong Quote
