Klotzban1 Posted October 29, 2004 Report Posted October 29, 2004 ok...here is what I have in mind. Let me know what you all think before I start. I cut my airbox so that my K&N filter will have more airflow. Everything from the filter to the reeds are stock. My front part of the air box is like a plate now holding my K&N with a K&N Pro Flow adapter. Looks pretty solid! In my signature I'm jetted 260 at an elavation of 1042 ft. Before I start my Shee I want to get the jetting close to right to avoid a problem. I've heard alot of people say that if you run too lean it can also cause overheating so also I'll mention that I still have the stock radiator on my bike. Quote
FIRST BANSHEE Posted October 29, 2004 Report Posted October 29, 2004 That sounds a little lean. when i had fmf pipes and stock carbs i was running 270's and 280's on the mains. hope this helps Quote
sandornothing Posted November 1, 2004 Report Posted November 1, 2004 Dude that is a sweet set up. I did the same myself. It feeds your motor the same amount of air as clamp-ons do, but without the hassle of burnt outerwares from the pipes. I went up from a 300 main (lid removed) to a 330 main (air box cut off). I hope youre riding in dry terrain because this set up will screw you in wet shit. Your filters will require some more attention now, I clean my filter and outerware every night when we're out at the dunes. Youre going to want to go up on the pilot too. I did 30's, and 2 full turns on the air screw. Hope this helps......it helped me. Quote
stclark04 Posted November 1, 2004 Report Posted November 1, 2004 (edited) There is no way that you can just come up with a jet size that is going to be perfect. Ride it and do a WOT plug test. Its not going to hurt if you are a little lean when doing a plug test. Thats how you find out what your jetting needs to be. Just go up on the main 1 or 2 sizes and do the plug test. Thats how you are gonna get the jetting you need. EDIT: What size pilots are you running? Edited November 1, 2004 by stclark04 Quote
