well if i cant sell my shee as a whole i might peice it out in a few weeks if i get enough people interested in some of the bigger parts so heres a list, leave a price and the part if you would be interested, thanks
and remember, this is aftermarket, ill still have the cases, bottom end, things like radiator and such to.
Engine
Fresh rebuild top and bottom
Fresh EBC clutch
New stock clutch basket
Pro Design fully adj. Timing plate (set at +5 right now)
Weisco hot rods and crank
Fresh Weisco .80 Prolight pistons
Brand new Noss coolhead with 21cc domes
33mm Pwk Keihn carb, with Trinity stage 4 , 2-1 intake system
Single K&N filter with outerwear, with Prodesign plate for 2-1 system
TDR epoxy reeds
Procircut Platinum pipes and silencers
Mild MX port and polish
NGK plug wires and caps
Inline fuel filter
Inline water cooler
Jetted accordingly.
Boltons
DG nerfbars with new nets
DG bumper
New DG grab bar
Billet parking brake block-off
Epoxy case saver
Race full engine skidplate
Locknut Axle nut
Epoxy chain sliders and roller
Chrome and Polished
Chrome Grill
Chrome Gas cap
Chrome Water Pump insert
Chrome Clutch cover instert
Chrome Flamehead dipstick
Chrome rear brake ressy cover
Polished front brake lever
Polished rear brake lever
Polished Shift lever
Polished Kick starter
Controls
Renthal Fat bars
UFO hand guards
RTC clutch pertch and lever
Prodesign Kill switch
Moose grips
MotionPro Twist throttle
Looks
New Front plastics, tank cover and rad. Cover With Alba flame graphics
Ceet Seat cover
Newer stock rear plastics with Ceet graphics and race sticker kit
Painted Stock swingarm gloss black
Painted bearing carrier Gloss red
Painted hubs Gloss red
Painted Sprocket carrier and brake rotor Gloss red
Red moose shock covers all the way around
Renthal red cross bar pad
Custom
Water temp. guage
Footpegs welded to frame with kickups
Rear fender Brackets
Clear stator cover
Rebuilt kick starter
Run Wiring/Tubing
Removed
Lighting system
Parking brake assembly
Extra wiring/tubing
Chassis/Tires
95 engine and frame boltons
91 frame with J-A-arm conversion Painted gloss black
Armadillo +2+1 Racing A-Arms
New front 20inch .190 ITP rims with 20inch Kendra Klaw MX tires
Rear 8 inch .190 ITP 18inch Turf tamers MX tires
the guy asking about my engine, pm me we'll talk about it, if i get the engine and some of the other big things sold, ill start piecein out in a week or 2, thanks, anyone else? ill get back to the rest of you about pieces if i get more parts sold
Billet Parking Brake blockoff
Polished clutch insert
Twist throttle setup (assuming it would work good for my 35 single setup ;) )
Temp Gauge (if it's easily swapped over)
damn, looks like alot of parts would be going quicker then i thought. still workin on a deal on the engine, then maybe ill tear into the rest
