German Shepherd Posted October 1, 2004 Report Posted October 1, 2004 I ride in the woods but I need mega power to get up those coal hills. I will post the link of the pics later. I am thinking of doing the following to my next banshee. V force II reeds, rocket-T5- or fatties, Dyna FS ignition, larger carbs but what brand and how large? I dont want to lose all my bottom end because I ride trails to. A boost bottle, How much porting/head milling, I heard passion was good on here? What does it mean to lighten a fly wheel, how much is it?, Kand N filter with air snorkal removed, and what else? Remember I am looking to keep the reliability of stock, b/c I ride sometimes very far away from people. Thanks Quote
SyNtAxx Posted October 1, 2004 Report Posted October 1, 2004 Hello, i prolly have the HP numbers your looking for. Here is my set up: 95 Shee Bored .10 Milled head (.027) FmF Fatties w Power Core 2's Passion MX port K$N with outerware +4 Degree Advanced Timing Bling Bottle (For Effect ) I have no problem climbing the monster coal hills. Coal Hill In treverton not a problem Nick Quote
rebelbanshee2 Posted October 1, 2004 Report Posted October 1, 2004 +4 stroker mega torque mega top end and reliable Quote
locogato11283 Posted October 1, 2004 Report Posted October 1, 2004 Eric Gorr's Forward Motion he does a badass woods port. thats what my brother has in his banshee and he will easily run with top end ported bikes. i think the port costs around 200 bucks. i highly recommend this port job. if you arent a believer watch some of our hillclimb videos and check out my brothers(stclark04) banshee. its fast. hes run 17 tooth front sprocket on some of these hills too so i know hell pull a high gear. give him a call. Quote
DIABLO BANSHEE Posted October 4, 2004 Report Posted October 4, 2004 I'm actully pulling the same numbers your looking for,my shee has tons of bottom and mid range,i was pulling 58.3 rwhp until i put on the cool head and advanced my timeing to 4 deg.now i'm dueing 67.8 rwhp .call carlos at cg performance in san deigo 619 440 9494.tell hime Eli sent you.i swear by his motor work.i promise you'll love the motor after he is done.if you need my first dyon report i can e-mail it to you.the new one is with carlos for now. Quote
decon Posted October 4, 2004 Report Posted October 4, 2004 dont get bigger carbs, u will lose bottom/mid range power. u need more mid range for woods and coal hills. get some fattys, dont get a boost bottle, they are worthless crap. lightening the flywheel takes off the mass allow your banshee to rev faster and increases throttle response, costs roughly around $60? if you want some real power, get a 12 port stroker from passion racing, http://www.passionracingengines.com/ . if it costs too much just get a mild port. a trinity 2 in 1 35mm carb setup is real good for low end and mid range, http://www.trinityracing.com/ . Quote
cyp65 Posted October 15, 2004 Report Posted October 15, 2004 Hey, Im new to this, but I live in NEPA where the coals banks are the thing to ride. I have no problem with what i put together. Its reliable and puts out awesome power to climb everything. .80 over Wiseco Longrod pistons --- only .80 because thats where they needed to be bored to Wiseco Hotrods long rod crank --- welded and trued Delta V-Force 2's Keihin 28 pwks adjustable timing plate with 4 degree advance t5's Hinson clutch parts Its run amazing and I have yet to find a hill i can't climb. Quote
Banshee~ Posted October 17, 2004 Report Posted October 17, 2004 Get Rockets,Woods port,longrod,coolhead with 21cc domes and you will be screaming Quote
super88_banshee Posted October 22, 2004 Report Posted October 22, 2004 (edited) I don't know what kind of power i have number wise. my mods are listed below Toomey T-5s K&N Pro-Flow kit Vitos SS pistons .20 over Head Milled .35thousands Smoothed intake & exhaust ports Case matching 290 jets in stock carbs +4 timing advance Boost Bottle Boysen Reeds w/ stock cages 14/42 gearing I too have yet to find a hill that i cannot climb. You can start at the bottom of large hills at L.S. and keep runnin thru the gears all the way up(generally only use third at most). It is kinda doggy on bottom end thou. I was thinking about the future and debating between a +4 stroker/longrod crank, or the trinity 2 into 1 carb setup?? i don't know which one i would enjoy more. I'm also thinkin about flywheel lightening. Oh how i wish things could be free Edited October 22, 2004 by super88_banshee Quote
