1 throttle + 2 carbs = 3 springs
Couple options
1. Suck it up and deal with it. :cry:
1.5 Lube cable
2. If TORS removed, can remove spring from throttle housing.
3. Buy an extended thumb throttle.
4. Switch to a twist throttle.
5. Have heard of people running a file over the slide springs to weaken them, but would never do it myself.
6. Switch to a single carb setup.
7. Sell your shee real cheap and buy a 4 choke.
Edited by hops
The first day i had my banshee, TORS was removed and the spring was removed, forget that stiff throttle. Everyone else in my riding crew is too lazy to remove there system, so they take a 10 minute time out every couple of laps because they're cramped up, forget that! :clap:
Where is the TORS(Throttle OverRide System) located, and where is the spring located.
Can't you keep the TORS since it is important to have it and just take out the spring.
Can you please elaborate on these stuff.
Could try taking off your skirt and putting on some man pants :P Nah. Lube your cable up good. That's probably the one main thing that's makin it stiff. I'll lube up mine and it'll be like there's nothin there. Same with the clutch, I can pull it like there's no spring being pulled when it's lubed up good. Good luck
Man, when i lube up mine it get's nice and stiff. i don't worry about a spring but it get's pulled pretty hard. :yank:
Edited by sheeweet
