xt45
Everything posted by xt45
  1. which one lasts longer 2 strokes or 4 strokes and why
  2. MudSlinger09, what is your proof that hes being sarcastic. Thank you in advance if you answer the above question.
  3. Thank you 347cid for calling my question "Great". Appreciate it.
  4. what if you tried it in that manner and waited and waited and it didn't blow up, then what are you going to do
  5. How many minutes does it take for the shee's engine to blow up, having it in the first gear and full throttle ? What are the sequence of events happening from the time you put the shee in the first gear and full throttle until the very end ? Please, be specific. Have a good day.
  6. what trend
  7. who likes to do spinning and doing donuts, and who hates it what was your maximum time you did spinning, how many minutes, pictures ? videos ?
  8. please, feel free to answer any manner that you feel comfortable, funny way, serious way, any way so what happens eventually to your shee, as the temperature is going higher and higher, and you are not doing anything about it please, be specific in the answer
  9. how would you know if your shee is heating and what will happen if the temperature rises very high
  10. Which One To Buy Brand New Banshee or Used Banshee and Why
  11. what happens if you keep ur shee compeletey stock
  12. Let Us Assume It Is A Stock Banshee what is the best method of shifting so you get the best of each gear and then go to the next gear when is the time to shift to the next higher gear what is the best method to shift
  13. Fuel cock, do you have to put it on "reserve" or "on" or "off" when you are filling with gas/oil when you fill, does reserve tank gets filled first and then the main tank
  14. when your shee is new, how do you drive it how long do you warm it before each ride how much throttle do you give it how many hours of slow riding do you do when can you go at full throttle and use it normally
  15. what do you think of my questions
  16. how is the stock tires in the dunes does it take you all the way up, or is it a must to put the paddle tires to climb the dunes.
  17. stick to yamalube all the way, do 20:1 and she will live for a long time.
  18. Where is the TORS(Throttle OverRide System) located, and where is the spring located. Can't you keep the TORS since it is important to have it and just take out the spring. Can you please elaborate on these stuff.
  19. so we are talk about 2 springs. One in the throttle. The other in the carberotor. So how to deal with each spring.
  20. how can you loosen up the stock thumb throttle
  21. if you see fit chicks, what would you do to impress them using your banshee
  22. Banshee Accidents, What Body Part Did You Break ? How did it happen ? What could have you done to prevent the accident ?
  23. Give the full throttle and then you get the boost in the power after 2-3 seconds, why ? What is happening in these 2-3 seconds ? Can you please explain the process. Thank you.
  24. What is the closest atv to Banshee that you can buy today in terms of the Adrenaline Rush and Wheel Spin ?
  25. Why didn't Yamaha add oil injection systems that mix the oil and gas automatically ? what is the disadvantage of have this oil injection system in Banshee. currently you have to do the pre-mix but with the oil injection system you have to only pour gas in the tank and yamalube in another small tank that the oil injection system will take care of it as far as mixing is concerned. Yamaha could have also put an option to switch off the Oil Injection System so those who want to do thier own mixing ratio can do so.
