sweetshee4312 Posted August 24, 2004 Report Posted August 24, 2004 Ok, get my shee up and running, for those of u tha know, thats a huge acomplishment.... Im riding down the road, and i notcied the front right wheel looks like its a damn oval, like when it spinds, if u watch the gap betweem the brakes it gets bigger then smaller as the wheel goes around, and when i ride the bike is going up and down....like a hoarse.....Wha can cause this, i know my left a-arm is bent alittle, inward.... casue i hit a tree but it doesnt it the spring, so im just gonna leave it, i dont see wha its hurting, whaa could be bend or tweaked or wha?? Quote
fast500#12 Posted August 24, 2004 Report Posted August 24, 2004 (edited) did your wheel hit the tree to? your wheel might be a little smashed. that would explain the bouncing up and down feel Edited August 24, 2004 by fast500#12 Quote
sredish Posted August 24, 2004 Report Posted August 24, 2004 i'm guessing it's a furked wheel or it's not bolted on right, could be a spindle too though. take a vid and send it to us before you fix it. Quote
locogato11283 Posted August 24, 2004 Report Posted August 24, 2004 id say bent spindle or wheel bearing maybe. Quote
sweetshee4312 Posted August 24, 2004 Author Report Posted August 24, 2004 Ok....whats a spindle, how do u tell if its broken.....and same with a wheel bearing, i did the whole axle bearing casue they were bad about 6 months ago..... it is bolted on all the way...i cheaked tha, it scared eme to go fast, casue i think its gonna fall off (this already happened to me once)...thanks for the replies Quote
sredish Posted August 24, 2004 Report Posted August 24, 2004 don't you have a service repair manual? Quote
SHEEBANSAVAGE Posted August 24, 2004 Report Posted August 24, 2004 Swap tires from side to side and take it for a spinand see if it swaps sides or not. I had the same prob after my full rebuild and the rim was bent. Quote
sweetshee4312 Posted August 24, 2004 Author Report Posted August 24, 2004 ight will try, i gotta get a link breaker or w/e its called for my chain casue it fuckin broke....where can i get links for my chain to? Quote
