The ball and the pushrod in my cluch got stuck together, I got the ball out but I cant get the push the rod out, its not stuck on anything and it moves when i press against it with a screwdriver. I cant get grab it, how do you remove it ?
Thanks,
Mike
Edited by 00BlueShee
turn the bike over to where the clutch side is facing the ground. and to prevent the ball from seizing up on the rod again u can do one of two things. u can by a clutch saver which u can get from any engine builder or performance shop just about or u can take the stock push rod and ball and heat it red ass hot and drop it in a bucket of water this changes the temper of the steel and make it not weld itsselft together anymore
I tried turning it over, I put some extra oil down the shaft also to try to make it slide but it just wont go. I have a magnet that can pull it, but its not powerfull enough to pull it all the way threw.
take the actuator arm out you need a dremel and a long bit. what happens is when it welds the rod gets so hot that it melts into the actuator arm and creates burrs on the end of the rod making it so you can't get it out. take the magnit you have stick it on the basket end of the rod you should be able to spin it around take a mag light shine it through the actuator hole and you will be able to see the burrs on the end dremel away. this will save you from splitting the cases.and change the tranny oil after 1st ride. hope this helps
ok i got the push lever out, its got some bad wear on it so im gonna replace it, I can see the push rod and im able to move it back and forth a lil.Im gonna get the dremel out now.
thanks everyone for all the help so fare.
