Shee_Man Posted July 26, 2004 Report Posted July 26, 2004 DG National Pipes and Silencers... I know a few of you hate these and they have a bad rep on the forum. How much more power would I gain switching from these to another brand? They're still alot better than stock then? If I switched to pro-circuit pipes would I gain much and where (bottom-end, mid, top) compared to the DG's. Quote
roosthrower Posted July 26, 2004 Report Posted July 26, 2004 keep what you got. on a stock motor, you will probably be disappointed when you only gained 1 or 2 hp from upgrading pipes. instead advance the timing 4 degrees are buy a he happy with what you got. Quote
Shee_Man Posted July 26, 2004 Author Report Posted July 26, 2004 well... I have a noss head on the way as well as pro-circuit silencers (will they match up with the DG's ok you think?) also K&N filter and quite possibly v-force 2 reeds... also timing has been advanced already (not sure how much though) So I won't be fully stock. So the DG's aren't "that" bad then... still a large gain compared to stock and almost as much as "good" pipes? Quote
lincster Posted July 26, 2004 Report Posted July 26, 2004 Anything is better than stock. Although, I did notice a big difference when going from DG to Toomey. Quote
frocashmoney24 Posted July 26, 2004 Report Posted July 26, 2004 like they said, there better then stock, but it looksl ike your going for a more powerful engine, so i'd just go order the pro's i know i love em Quote
Shee_Man Posted July 26, 2004 Author Report Posted July 26, 2004 So the DG's are good for stock engines? But they don't respond well to mods? where as the PC's are designed for modded engines? I know the PC's are designed for top-end... will I loose low-end and mid range switching from DG's to PC's? Quote
sredish Posted July 27, 2004 Report Posted July 27, 2004 So the DG's are good for stock engines?But they don't respond well to mods? where as the PC's are designed for modded engines? I know the PC's are designed for top-end... will I loose low-end and mid range switching from DG's to PC's? don't know how the dg's are, but the PC's have a decent bit of midrange, from what I gather, i don't really know too much about them either, just from what I've heard. The PC's are a mid to top pipe, but come on a little higher than say FMF Fatties. Quote
