Reed
I have Trinity 2-1 35mm carb setup and was running 162 Main, Just installed G3 Reeds with 12mm spacer not sure what to rejet main to. And or do you have to do pilot and needle. Anybody no what main to use, or can suggest something. Are you supposed to go up in Main or Down. The guy at dirracing sent me 190, 200, and 210 but didn't sound like he was sure what he was talking about. Now I have fuel coming out bottom of bottom nipple on carb when I rev Up. Please help :wacko:
You'll really need to run a plug check to know if you need to go up or down on the main. You may have to lean some or you may not have to anything, only way to tell is to check plugs, and the only one that can do that is you. Read the BansheeHQ Jetting FAQ to get more info on how to do that.
Reeds won't affect fuel coming out of the bottom of the carb, maybe the plug is loose on the bowl.
