i've been wanting to replace my stock air box and air filter...i was wonder what set up would get the most power w/the most protection...also what kind of jets would be good to get after i do this.....just wanted to hear some different oppinions i'd appreciate anyones help. Thanks
I got rid of the factory airbox and use the Toomey 2:1 setup with a Uni filter and Outerwear. I'm very satisifed with it. I haven't used other setups so I cant compare. But I have no complaints. Jetting would depend on your pipes, elevation, temp, etc.
I will second the vote for the Toomey 2:1. Great filter, gets rid of alot of the clutter that the giant airbox causes. I ran it for alomost two years until I stepped up to larger carbs. They make a water resistant Outerwear for it that works great(but can burn easily on the stinger tubes).
broke
i use the pro design set up and it wokks great also i took off that dam hose thing and put in 12 1" air hole things
good air flow and the outerwear for the pro design realy keeps the iner air filter clean as hell
if you want to keep your air box and just ditch the lid talk to david noss he sold me an billet adapter with K&N filter and outerwares for about $100.K&N makes a airbox lid that filters there air and is reuseable and outerwares make a cover to
you runnin in sand? if ur in sand i say ditch the box, and get 2 clamp on filters, if ur runnin in dirt and mud n shit, isay keep the box, off with the lid, and get a 2-1 setup by k&N, foam filters suck in my opinion in mud n dirt
