geaux 4 it Posted June 22, 2004 Report Share Posted June 22, 2004 It's hard to shift it on the table because the tranny isn't moving as fast .Look at the shift shaft & make sure it isn't bent. Quote Link to comment Share on other sites More sharing options...
Oilsmoke Posted June 22, 2004 Report Share Posted June 22, 2004 Dude Use your tranny. Don't go to a Stealership. Remeber if you did it once you can do it agian ,If need be. ( teardown & rebiuld ) But i betting you will be ok, My banshee was a old worn Dune machine when i bought it, That is why i think it trashed 2 gear. I paid 2800 and then i added about 3200 to it. It's Solid Dune machine now. It runs great but I am still tunning the 34 RS mikunis for full power. I won't push the jetting very fast so i ride and check plug and drop it every ride, I am at 290 main and looking like 270 to 280 it where it will end up. Not sure about the washer rubber thing ? tell me more. I ride at Siant Anthony Id. I need to get some pics up . Quote Link to comment Share on other sites More sharing options...
troyminator Posted June 22, 2004 Author Report Share Posted June 22, 2004 Very Cool Oilsmoke! I am ride in Southern Cal/Arizona (Buttercup,Glamis,Gordons). As for the tear down and re-assembly (I would just hate to trash something else too:( That is my bike before I started the tear down and rebuild at the top of a bowl at Buttercup. Like I said...I can't wait to get the new motor in...I am kinda worried about getting the jetting right, but I will play around with it slowly too As for the washer thing... there is a link below to a previous post I read>>> Later, T Shift Shaft Adjustment Quote Link to comment Share on other sites More sharing options...
