they will break in and move a lil just need to ride it. My problem is my rezzi hitting my top a-arm but i have piggybacks.
:rolleyes: lol....go figure, they might be hitting the shock.....and it might not be fixable...... you should run and do this :shootself::flush:
Nah man, good luck, let us know how it goes. Dude selling the arms just keeps digging himself into more shit.....you should feel lucky you at least got to try to put them on your shee to see if they even work.
As long as they're not hitting, they should be alright, just keep an eye on it.
Edited by .
Do they have adjustable heim joints? try setting the aft ones in a bit and bring the front ones out, it will give you a bit more clearance...If you don't have adjustable upper A-arm heim joints..then your fucked as you won't be able to adjust the castor angle for the spindle.(Who came up with this terminology?)
Oh, you should also be able to A: adjust the res. sitting angle or B: add a shim to the side with the least amount of clearance.
Edited by MotulMonsta
