OC-SHEE
Everything posted by OC-SHEE
  1. let me know if you would sell the head and domes from the motor??? Im very interested and ill give you my stock one for a lil money off.
  2. I have a dynoport 2 into 1 pipe,and a trinity 2 into 1 intake. I have a 35 pilot in there with a 172 main and the needle on the 4th clip or one above the middle. It jumps real quick on take off then it dies and then it hits hard. I can't go any smaller on the pilot nor would i want to. I need an idea as to what i have to do to get rid of this problem. The only time it ran ok was when it was 90 and humid. If anyone can help let me know. Plugs look alright. Its just the one area is dead. Try to IM me if possible on AIM(at the bottom). Thanks, JOE by the way i have a ton of jets so let me know.
  3. they will break in and move a lil just need to ride it. My problem is my rezzi hitting my top a-arm but i have piggybacks.
  4. nope just pop the seals out, then pull or if they are in there tap the bearings out then pack the new ones and reinstall the seals.
  5. OC-SHEE
    Gearing Again
    the cost isn't a big deal. I wonder if a 15 toothe will interfere with my case saver??? Anyway I guess ill try a 15 up front and pick up a 40 and 38 rear.
  6. OC-SHEE
    Gearing Again
    my internal is stock. But i have a 2 into 1 intake and a 2 into 1 pipe. I know i have mostly low end but that what i need but it doesn't seem right to be needing to shift so much even when i went back to stock gearing it felt the same as that 13 i had put in b4. So you think a 14/38 would be prety good?? most of the tracks are small to mid. Nothing national size or anything. I just don't think i should need to be shifting into 6th and only be getting like 50 mph prolly less. I rev out way to fast.
  7. OC-SHEE
    Gearing Again
    yeah but i have 18 inch tires! i dono what i should do then should i go to a 40 rear or a 38 rear?
  8. OC-SHEE
    Gearing Again
    so should i go with a 15/38?? or will i be good with a 14/38 or 14/40??
  9. OC-SHEE
    Gearing Again
    Ok so i went from a 13/41 to a 14/41 setup and i still rev out the gears way to quick. I'm in 6th and it feels like i went no where. So im wondering if maybe a 38 in the rear??? I'm not sure. I have the 2 into 1 carb also and the 2 into 1 pipe. I should not be shifting so quick. Ill be on the mx track of course and i guess you could call those track small to middle size. But out of the gate i'll be in 6th when others are in like 3rd. I know we have one more gear. I need help as my first race is next weekend. Thanks
  10. yeah i really feel you should either replace your rings since you took the top end out and if you feel the bore is bad i would really bring it to be rebored and you will need new pistons. But you should get new rings and try that first.
  11. then maybe i really need to go lower on my pilot even though im at a 42. Well ill be bringing it to be tuned cuz im sick of playing with it.
  12. well i sat for a whole nother day playing with the damn thing on monday so now its either going to speed freeks or my friends shop to be tuned. Im done after spending more then 70 bux on jets and still runs like shit. By the way now i have a 165 main in and a 42 pilot with the needle in the middle and the air fuel 1 from closed. Still doing the same shit. So now i give up because i need this done.
  13. i dono why you just don't go to a dealership and get them right away.
  14. Ok just wondering if anyone else had the setup. This a brand new top end. I have a 172 in the carb now down from the 180 they supplied. Its still rich because when i remove the plugs after a lil running it looks like unburnt oil on the plugs. I dono if i should leave it this way till brake in is over or should i go down to a 170 and lean it out with the needle. Also could my pilot be too big? I have no bottom rev its bogs when i blip the gas. Any help would be appreciated as I intend to be at the track this week and race this weekend. Thanks-JOE
  15. Ok just wondering if anyone else had the setup. This a brand new top end. I have a 172 in the carb now down from the 180 they supplied. Its still rich because when i remove the plugs after a lil running it looks like unburnt oil on the plugs. I dono if i should leave it this way till brake in is over or should i go down to a 170 and lean it out with the needle. Also could my pilot be too big? I have no bottom rev its bogs when i blip the gas. Any help would be appreciated as I intend to be at the track this week and race this weekend. Thanks-JOE
  16. I have a Dynoport pipe and a 2 into 1 carb. I have 13 and 41 rear now but what do you think i should change too maybe a 14 front?? The tracks are not wide open I dono how to describe them but nothing like a nats so maybe tight. Let me know cuz if i need to change my gearing i need to get the stuff now.
  17. OC-SHEE
    Gearing
    What gearing are all of you MX banshee racers using. I have a 2 into 1 carb and a 2 into 1 pipe and i have a 13 tooth and 41 rear. I dono if i should go up to a 14 let me know what you think
  18. i was being stupids i thought the retainer had to go all they way in to hold tha cable in. It only goes down till its against the needle top and then the line slips in and then the lil plastic piece on the spring holds the line in. Thanks for your help guys.
  19. I have the whole carb installed but when you put the throttle cable into the slide the retainer has a place for a socket or whatever and the cable gets in the way of tightening it down into the slide. Any help is appreciated
  20. watch it boy no need for stupid insults, and thanks Clint. The reason i do not have a service manual is because im waiting for my dealer to get it in. But i want to have it done.
  21. I need help!! I whipped my whole computer one day and the one thing i forgot to save was the pics i took of the quad. If someone could take some pictures of everywhere the wiring goes and where everything mounts it would help me a great deal. Thanks -JOE
  22. well i have some parts. This guy on here said he sent the paypal but it never came so the a-arms are still available. 170 shipped. And tom. if the guy does not come i may still have my swing arm and stock axle. I do also have a steering stem.
  23. can you pay pal man ill definatly take that. oh and add 20 to ship its prolly more then that to ship but ill take the 20 to cover most of it.
  24. axle 70 shipped to your door if you wish its from my '02
  25. which hooks the ones that hold the wires in or the metal hooks for the air box lid?
