Kg8 Posted April 24, 2004 Report Share Posted April 24, 2004 The slide on the right carb sometimes sticks when i hit the gas, i cleaned the carb and the slide but it still sticks about 75% of the time can anyone give a suggestion.......oh and has any1 tried out the new LRD RFX pipes? Quote Link to comment Share on other sites More sharing options...
reas11 Posted April 24, 2004 Report Share Posted April 24, 2004 are they stock carbs?i would check the throttle cable, if it has a kink in it that would cause the slide to stay open, also if they arent stock carbs is the idle screw in to far or did it fall out completely ? all good place to start when the slide sticks. Quote Link to comment Share on other sites More sharing options...
J..J. Posted April 24, 2004 Report Share Posted April 24, 2004 Reas got it covered, also check that the needle isn't bent. Quote Link to comment Share on other sites More sharing options...
Banchetta Posted April 25, 2004 Report Share Posted April 25, 2004 Good job reas!!! Quote Link to comment Share on other sites More sharing options...
PlaynSand Posted April 25, 2004 Report Share Posted April 25, 2004 I have stock carbs and after jetting and needle changes several times I must have gotten a little grit on one of the slides , It was sticking wide open on one carb sometimes , still a scarcy feeling . I disassembled the carb and cleaned it out with carb cleaner , but it was still sticking, So took some 600 grit sandpaper and lightly sanded the slide by holding the paper around it and turning the slide in the paper , did this just enough to get it smooth. Cleaned again with carb cleaner and no more sticking. I have a set of RFX pipes and for my style of riding I like them , they have a very smooth power delivery and very strong midrange, I like these or CPI's but I burn my leg to much on the CPI's . I have only rode FMF fatties , PT mids , LRD's , and CPI's ,so I really don't know how they compare to other pipes, Toomeys and Pro circuit are pipes I see a lot of but I have never tried them. Quote Link to comment Share on other sites More sharing options...
