I i'm wanting to flush my shee's radiator ,what kind of name brand product is best to do this job?Can i find it at a auto store? The only auto parts stores we have around here are AUTOZONE and CHECKERS. THANKS FOR YOUR REPLYS. :)
There's an actual acid flush you can run through the cooling system. Did that on my S10. You'd want to check and make sure it wouldn't hurt anything on the banshee, though. I got mine at Autozone if I remember right...
arnt you supposed to run a hose through it?  i havent ever hear or some special product for the purpose.
They do make fittings to flush it out with a garden hose, at least for automotive applications. You remove the thermostat and lower radiator hose and basically garden hose out the whole thing. Seems to work well. But, they do also have an acid flush product that's supposed to help remove some of the junk that builds up. Not sure how it'd like that plastic impeller though... but it works fine with rubber hoses, etc. If Autozone/Advance doesn't have it, a GM Stealership does..
