One of the rear studs that holds the wheel to the hub stripped out on me today. My question is do I have to replace the entire hub or are the studs replaceable? How safe is it to ride on 3 out of 4 nuts holding the wheel to the hub?
just replace the one. go to the yamaha dealership. they arent too much money. 2 or 3 bucks i think. beat out the old one with a hammer and take it in when you go. you dont want blaster hubs. they are for an 8 inch rim. i doubt they would even fit on the axle.
At least with my S10 and stuff, if you need to install a new stud and it wants to be pressed in and you don't have a press... use an impact wrench. I broke 2 studs on one of my rear S10 tires the first time taking them off. Just old and brittle and rusted. Got some new ones at the auto store but didn't want to take the whole axle out to put new studs in. You can just put a couple washers in the other side, put a nut on it, and torque the nut with an impact wrench and it'll draw the stud through so its seated where it needs to be. If you're careful you should be able to do the same thing on the shee hub.
