ok i have a 2000 banshee, only mods are fmf pipes and aftermarket air filter and i used the provided jets that came with the pipes...for 2 years with the new jets its ran perfect, there has never been the need to replace anything. the last couple days at low rpm's its kinda bogging and back firing. the jetting has never been a problem in cold or warm wheather. i changed the plugs to brand new plugs problem still exsists, my fuel mixture has always been right on, it starts up first kick no problem so i dont think its anything to do with compression.....after about half throttle power is still emaculate. its just at low rpms it seems to studder and backfire and lose power almost.....but if i just full throttle it its running perfect. what could the problem be ? please help
I had the same problem with my 89, and changing the pilots and upping the main alot fixed my problem. How do the plugs look and have you put new plugs in a runit at top end and shut off to get a good read on them??? Check that first and start playing with your mains, I ride in the California sand dunes for me, pilots of 35, mains 320 with FMF fatties, K&N aftermarket airfilter.
