I have a set Of MP racing struts,adjustable from stock height or you could have the shee sittin 4 inches off the ground,Ran one only mounting marks,Ill give them to you for 60 shipped you can check em out at www.mpracing.com
Go to Lowes, Home Depot, or some hard ware store... Look for 1 inch round tubing... Aluminum... Thin wall Steel... or something... If you try to get too low ur gonna rub your tie rods against your pipes... if you have drag pipes or I believe T-5 u wont have a problem... but i took my round tube and cut them 12 inches long... then i took and came 1/2" off each end made me a mark in the center and center punched it... Do the same to the other side of the pipe... Then drilled a 13/32" hole, (lil over 3/8") made 2 of them and they work perfect.. Be sure you dont make the holes too big for your shock bolts... It will leave slack in ur struts and its not a plesent ride... I dont reccomend ridding down a bumpy drive way with these struts... Reply if you want my Ideas on the rear struts....
Later, Derrick
  • 3 years later...
