LIsurfer_ Posted March 22, 2004 Report Posted March 22, 2004 I need some tips on how to go about replacing the chain roller that mounts on the swingarm. If someone can give me step by step instructions on how to do this I will be most greatfull. thx Quote
"thenewguy" Posted March 22, 2004 Report Posted March 22, 2004 never done it before and dont have a manual but hears what i would do. put it up on blocks. take off the shock and then take off the swing arm. while its off check the seals clean and greese them replace them if you have to. then put it back on. Quote
SDD Posted March 22, 2004 Report Posted March 22, 2004 It depends on what brand you get. First remove the chain. If you buy the UPP brand you just have to cut the old wheel off and the metal bearing sleeve under it off. Then you open up the UPP slider and put it over the swingarm and tighten the screw down. Put the chain back on and adjust it. If you get a cascade you have to take the swingarm off basically. Quote
robinson373 Posted March 22, 2004 Report Posted March 22, 2004 I just bought the TM Designworks slider and took my swingarm off tonight. Do i need to remove the metal bearing sleeve? It looks as if the hole in slider is much larger than that of the swingarm. Is this normal. Quote
Nighty Posted March 22, 2004 Report Posted March 22, 2004 The metal bearing sleeve must be removed, my slider fits exactly over the swingarm (tight fit) the little arm(on the back of the slider) rests on the upside of the swingarm. The upp website has instructions. Quote
lincster Posted March 22, 2004 Report Posted March 22, 2004 I just bought the TM Designworks slider and took my swingarm off tonight. Do i need to remove the metal bearing sleeve? It looks as if the hole in slider is much larger than that of the swingarm. Is this normal. For the TM Designworks, no you don't remove the metal piece. That is why the hole is so big, so it fits over it. Quote
LIsurfer_ Posted March 23, 2004 Author Report Posted March 23, 2004 Thx for the tips. Where can I get a UPP part online? My local shops don't carry them. Thx Quote
SDD Posted March 24, 2004 Report Posted March 24, 2004 The side that has the big hole fits towards the outside. The metal cap on the side of the swingarm fits into this hole. You have to cut the bearing sleeve off. Quote
