"thenewguy" Posted March 22, 2004 Report Posted March 22, 2004 does anyone know the screw size for the grab bar(rear bumper) what ever ya wanna call it. i need to know the size of the screw that goes into the frame.i need to tap it with some thing and id rather have the right size. tryed to get the one on that the previous owner had in ther but the thing snapped trying to get it in all the way. luckally there was enough meaat on it to take it out with the vise grips, lol. any help would be great. Quote
thecabinboy Posted March 22, 2004 Report Posted March 22, 2004 All Metric, either 5 or 6mm its 5:30am and I will check when I get back from work. Quote
flea49 Posted March 22, 2004 Report Posted March 22, 2004 The bolts you are talking about are 10 or 12 mm almost every bolt on a shee is 6,8 10,12 mm. Quote
Lightninn2 Posted March 22, 2004 Report Posted March 22, 2004 If I remember correctly, the heads of those bolts are 12mm. Those type of bolts are called flanged hex head bolts. Again if I remember correctly, a 12mm head bolt has an 10mm thread. Now I'm going from memory, so I'm not positive. A good way for you figure the size is take out a good bolt from the grab bar and take it with you to where you are going to purchase the tap. You can then make sure you have the correct diameter by sight and test the pitch by seeing if the tap and bolt threads you have mesh when placed beside each other. Quote
Fox73-Zz Posted March 22, 2004 Report Posted March 22, 2004 The heads are 12mm, but the bolt size is an M8, but I don't remember the pitch. The bolts with the 10mm head is an M6, and the smaller bolts in the plastic around the rad are M5's. Take the old bolt and try to match the pitch with a new, known size nut. Then buy a bolt with that size. Quote
"thenewguy" Posted March 22, 2004 Author Report Posted March 22, 2004 i dont have the orignal botls i think 1/4 20's are on there right now, lol. ill go get an m8 and an m10 to see what one fit. i already got the tap.just didnt want to destroy what little threads are left in there. whats the pitch? does that even matter? Quote
