kingbanshee_73 Posted March 13, 2004 Report Posted March 13, 2004 can anyone suggest a good place to get my cylinders bored and maybe estimated price.....thanks Quote
MotulMonsta Posted March 13, 2004 Report Posted March 13, 2004 A local bikeshop should do. They should charge anywhere from 45-60 bucks per cylinder. Make shure you have the new piston in hand and then after the bore check for burs on the ports and a good cross-hatch pattern running the entire bore of the cylinder. cross-hatch is the intersecting lines left from the honing machine used after the boring is done. They should be consistant all around and evenly spaced. Quote
kingbanshee_73 Posted March 13, 2004 Author Report Posted March 13, 2004 i live in the middle of nowhere so i would have to send them somewhere Quote
MotulMonsta Posted March 13, 2004 Report Posted March 13, 2004 Well if your gonna mail em/ Trinity makes great motors along with LRD. Quote
yamaha350 Posted March 14, 2004 Report Posted March 14, 2004 www.shortysracing.com will bore them for 40 each. Quote
frocashmoney24 Posted March 14, 2004 Report Posted March 14, 2004 u live in the middle of nowhere and so do i, take em to napa thy did mine for 40 a jug, but yea thoe rest of the guys posted some good palces outta town Quote
. Posted March 14, 2004 Report Posted March 14, 2004 I'm sure you can find a machine shop in driving distance......any machine shop would do it for around 40 bucks a cylinder I'm sure. Quote
lilbansheeman Posted March 18, 2004 Report Posted March 18, 2004 when u bore ur shee can u realy tell tha diffrence....or should u only bore it when u need 2? bcause a couple years back i had a blaster, couldne tell tha diffrence 4rm when it was stock to when it was bored..felt tha same to me Quote
350duner Posted March 18, 2004 Report Posted March 18, 2004 Don't bore to try to make more power. The extra few cc's won't do much and you take away that safety coushin for when you really do gouge or scrape the cylinders. LRD will bore for $40 a hole. If you want it overnight I think it's like an extra $15-$20. Make sure whatever shop you choose uses a boring bar/torque plates Quote
