scotts96fast Posted March 4, 2004 Report Posted March 4, 2004 I'm doing the shift star and lighten flywheel mod.I'll have it apart and thinking of replacing the clutch.I already replaced the clutch basket with a hinson one and heavy springs.The clutch is stock(1996).What is a good clutch kit to buy and from where?I do mostly trail ride and drag with the guys once in a while.I'm sure it's a good idea to replace the plates and steels right?(o'ring's to?) Thanks guys.... Quote
pimp559 Posted March 4, 2004 Report Posted March 4, 2004 Barnett Dirt digger is a real good one. Will last forever and pretty cheap. Quote
ledofthezep Posted March 4, 2004 Report Posted March 4, 2004 I'm running a Barnett Dirt Digger, about $113 from the local stealer, you can also get them from RockyMtnatv. That was for the whole kit, which I'd recommend. It does not need o-rings & that's also included in the little slip that comes with it....leave them out. I've heard great things about TUSK clutch kits,...like $40 for the whole kit from RockyMountain, but last I heard they were WAY back-ordered. That was some time ago, but I'd check them out. Had they been available when I replaced mine I would have went with a TUSK to save me some money. Hope this helps. Quote
sredish Posted March 5, 2004 Report Posted March 5, 2004 I've heard great things about TUSK clutch kits,...like $40 for the whole kit from RockyMountain, but last I heard they were WAY back-ordered. Yeah, they're still backordered. A friend just tried ordering. He went with my suggestion, the Barnett Dirt Digger. I also like those clutches and it's all I'll probably use, due to the good luck. Quote
421stroker Posted March 5, 2004 Report Posted March 5, 2004 I hear that the toomeys are pretty good also. Thats what I have. Quote
MotulMonsta Posted March 5, 2004 Report Posted March 5, 2004 With the barnette kit, run half the springs Barnette springs, the other half OEM. Space them every other one to keep equel pressure on the plate. You can run all 6 heavy duty springs but the lever will be REAL hard to use..even with an ez pull and Hyd clutch kit. Ez pulls will break cables. Quote
Phast Posted March 5, 2004 Report Posted March 5, 2004 A Toomey clutch set up is a really good one too! Quote
scotts96fast Posted March 5, 2004 Author Report Posted March 5, 2004 I just say the Vitio's clutch kit.Any good? Quote
ledofthezep Posted March 5, 2004 Report Posted March 5, 2004 You can run all 6 heavy duty springs but the lever will be REAL hard to use.. Mines not much harder to pull than the stocker was, I ran all 6 HD springs & have no problems. Either way will work, just preference I guess. Quote
Trick2stroke Posted March 5, 2004 Report Posted March 5, 2004 I put a dirt digger clutch in my blaster, and I put all the hd springs in a didn't notice any diffrence in how hard it was to pull the clutch in.. My left hand isn't my strong hand either...All the strength is in the right, if you know what im sayin.... Quote
ledofthezep Posted March 5, 2004 Report Posted March 5, 2004 Haha...I take it you're not into the kinky shit huh Trick2Stroke! scotts...check out the for sale section...."Dirt Digger Clutch Kits $75." http://www.bansheehq.com/forums/index.php?...opic=23438&st=0 Gotta love the HQ! Quote
Jeffro Posted March 6, 2004 Report Posted March 6, 2004 Magic racing has the barnett clutch for $89. I just ordered on yesterday. Quote
Blue Duece Posted March 6, 2004 Report Posted March 6, 2004 barnetts are nice....... use three stock springs, if you ride trails or tight stuff.....there hard to pull..... Quote
MotulMonsta Posted March 6, 2004 Report Posted March 6, 2004 Somebody who knows. barnetts are nice....... use three stock springs, if you ride trails or tight stuff.....there hard to pull..... Quote
