have been told rd350 barrel& heads are the go for maxin out yor banshee. is it true? i have 2 friends here with banshees who want to do it so i thort i ask u people. does anyone no where to get any rd350 parts is the big ? i spose.
Do a long rod 370 and you'll be very happy. On top of that you'll be able to get parts alot easier and faster and probably a little cheaper. ;)
you want the "rd350 ypvs" barrels and head(aka rz350). the none ypvs rd 350's had different stud pattern and old porting designs.
But its not that simple. These cylinders have electronic controlled power valves and different exhaust mounts.
I know this cause i have an rz350 as well as my banshee.
To do the conversion properly you will need the following
1. Cylinders and head
2. CDI
3. Stator and flywheel
4. harness
5. powervalve control unit
6. powervalve motor and cables
I was going to do it but Jim from passion racing told me to just use the stock banshee cylinders...
I do plan however on still using the RZ shift forks and drum and the stator for the extra watts...
Yup. I want a set of those shift forks too. Read some stuff about those and how they improve the shifting and would love to do that mod.. if I could find a set <_<
