workin on a buddies motor and having dome issues..... he is running a wiseco +4mm crank with wisecos 795 pistons. When running the motor thru full stroke (by hand) the tops of the pistons are hitting the domes. Both pro-design big bore 19cc's and noss machine 19cc's...the piston is coming up past the top of the cylinder .055" squish meas. The pro-design bb is .044"/noss machine meas. .035".
Port timing matched cylinders and pistons, so he does not want to run a baseplate. Any suggestions?
Current Mods:
T-5 Pipes
320 main /32.5 Pilots
Stock Carbs
Adjustable timing plate
K&N Pro-Flo
Noss Machine Cool head w/19cc domes
66mm 795 Wiesco pistons
Full race port/polish
Wiesco Hot rod +4mm Crank
